Trailer stabilizer question
Throbbin Rods
Lebanon, NH
Recently bought a trailer to haul my Kubota tractor with. I was looking at options for stabilizing the rear of the trailer while loading and unloading. There are many commercial stabilizers/jacks available that will fit the bill, but has anyone ever made their own to fit inside stake pockets? Just seemed to my like a simple solution. I am interested to see if anyone has done this.
Thanks,
Bill
matt_i
My gooseneck trailer has a set of "feet" which are essentially a weldment of U-shaped channel that's attached to the underside of the pivoting ramps. When the ramps are down, the botom part of the "U" is about 1-1/2" off the ground, the loading process squashes the springs down and puts the feet right on the ground. When the ramps are up, they basically stick straight out the back. Has worked great for loading my Hyster forklift, all 11,500 lbs of it. Very simple and no maintenance.
Bondo
Greenfield, Maine
Ayuh,... Most all equipment wagons are built that way,....
joe_padavano
Northern VA
^^^This. My Hudson 5 ton equipment trailer is the same. Of course, with the trailer attached to the truck, these supports don't even touch the ground when loading.
T
Throbbin Rods
Lebanon, NH
Thanks for the input. I don't have actual ramps, more of a combination split tailgate/ramps. It might be best to reinforce these and add the feet to support the trailer when loading.
hippie2cams
Huffman,TX
If your tractor is light enough to load on those ramps in the picture you posted, you're good to go. just don't try to load trailer when not hooked up to truck.
T
Throbbin Rods
Lebanon, NH
That's the rub, I think it is too heavy for that. I think I will end up reinforcing the ramps and adding feet.
Thanks for all of the input guys.
NUTTSGT
Northern Central Ohio
Have you tried putting some blocks of wood under the back of the trailer and raising the trailer tongue via the tongue jack ? As long as the trailer is still hooked up, this should keep the trailer from "bouncing/rocking" while loading and unloading.
luckyrxc
Thanks,
Bill
I have seen this done. Well sorta. I'm not sure if they used an existing stake pocket as I'm not sure you will find a piece of steel to fit well inside a stake pocket. What I recall seeing was a piece of 2 1/2" square tube welded to the side of the trailer near the rear. It was welded with the open ends facing the sky and ground. The stabilizer was a plate (foot) welded to a 2" steel tube that slid up and down inside the 2 1/2" tube. Both tubes were drilled so the stabilizer could be pinned in the up or down position. The male piece was drilled in several places so the height could match the terrain.
The system seemed to work well.
ibedayank
Columbia TN
wrong kind of trailer to haul a tractor..... you have a landscaping trailer not a cartrailer/ equipment trailer
