Trailer wheel bearing dust cap installation tools
mike93lx
Richmond, VA
I hate installing dust caps as they always get beat up. The ones with a rubber center cover are better but the regular rounded ones always end up at least a little caved in.
What do you guys use?
Northern tool sells this simple ring, but $12 (with shipping is too much) https://m.northerntool.com/shop/tools/product_200468660_200468660
I'm seeing larger metal drivers on ebay for about $18 shipped, but they look like they might be a little shallow for the caps with removable rubber center covers
06 DIESEL
Middle River, MD
I honestly have only used the ones with the rubber cover and install with a dead blow from Trusty Cook, but if you want to do the ones that are solid metal find a piece of pvc or steel pipe to fit them from the hardware store and beat on that instead of buying that tool.
sberry
Brethren, Michigan
Some sockets work but usually tap a screwdriver around the edges. Its not something I would have considered looking for a new tool to do. I fuzz a little grease around them too so water doesnt penetrate.
mike93lx
Richmond, VA
I think that works well for used caps, but the new ones always seem like a struggle, at least for me
mike93lx
Richmond, VA
I didn't think about pvc... I bet a piece of 2" will fit well. I'll try that, thanks
turbodave
IL/WI
One of the pieces from my ball joint press set is a perfect fit over them. I use that and a dead blow hammer to install them.
Eric29
Western NY
I like the review of it on the Northern tool site. Someone said it doesn’t come with instructions.
plinker
Northern Wi
The boss made a installer tool from a piece of pipe (likely exhaust pipe) with one end capped off, works well and no damage.
MushCreek
Upstate South Carolina
When I was commuting back and forth to FL with a trailer, I made my own bearing service kit. I made a press out of acme threaded rod to press bearing races in, and made a tool to install dust caps. Needless to say, in three years of running back and forth, I never had a bearing failure on the road. I've never had much luck installing those cheap little caps without a tool. I can get them on, but they look like **** by the time I'm done.
BTW- I need a pair of new ones, and TSC wants $20 for a pair of them! I ordered a pair online for $6, shipped to my door.
lardy1
I just refurbished an old single axle trailer. Everything from the spindles outward is new. Those new caps tapped right in with a rubber mallet and several light taps around the circumference.
After reading this I will be double checking them, though.
mike93lx
Richmond, VA
I feel like if you are diligent enough to have spare tools and parts, you are diligent enough to properly maintain bearings. I carry extra bearing parts as well, but doubt they will ever be needed
mike93lx
Richmond, VA
A $3 bearing cap is certainly not a precision piece, so I am not surprised some people don't have issues with them while others do
lardy1
Yes. I was using brand new hubs and brand new caps. I'm sure the ease of assembly was influenced by that.
lardy1
I'll be finding a piece of pipe or something after reading this. I never really gave it much thought until now. Removing old ones, on the other hand..........
There are probably a host of techniques I'm unaware of for that too.
mike93lx
Richmond, VA
I usually just use a thin flat blade screwdriver and work my way around. That part I find pretty easy
mikegt4
sw ohio
I use a 6" piece of PVC pipe for my dust caps. A 2" (or 1-1/2", it's 25 miles away so I can't be sure) is a perfect fit for 3500# axles.
mike93lx
Richmond, VA
It would have to be 2" as the smallest dust caps are 1.98"
It is possible that a 1.5" pvc fitting might fit as the OD of 1.5" tubing is 1.9", but I think that would be too tight
texasprd
San Antonio, TX
I haven't done trailer dust caps specifically, but for trucks/cars I start the cap on by hand as evenly as possible, and then tap it down gently with a punch or my steel-frame screwdriver - going around the cap 2-3 times.
Jazz1
Thunder Bay On.
I had some issues with bearings and started carrying a loaded hub. The newer bearing buddies with relief hole help I think. Have not done any bearings couple years now.
mike93lx
Richmond, VA
Bearing buddies and rubber caps... set and forget.
$40 for a trailer that will never be under water just doesn't make sense to me. Besides, I can get the caps with removable rubber center covers that allow access to the zerk on the end of the spindle.
I like taking the hub apart every 1-2 years anyway to clean and inspect. For a trailer than can sit for a bit at a time, I think it is a good idea to do that
dubdoc
Milford Station, N.S.
Hmmmm, never had a problem installing the caps, but removal is another issue. Soooo, just bought this superfine cap removal tool.
SeisMec
Beryl, Utah
For removal, I've always used an 8-12 oz ball peen to gently tap a cold chisel with a very slightly blunted point. The chisel's wedge does the work - forcing the cap to budge in 3 or 4 places and never ever leaves a mark. Channel locks finish pulling the cap once it's loosened.
Have seen new caps in three basic variations:
  1. Installs fine.
  2. No inward flare to the lip that fits inside the hub. Fix with twisted wire wheel on bench grinder.
  3. Out of round. Fix with gentle squeeze with large channel locks or a vise.
jsaw
Geneva, N.Y.
same here, except I might use a punch
