Transfer Pump
FMC1959
Montreal, Canada / Upstate NY
I am looking to get a transfer pump for fuel, something like this
https://www.amazon.com/gp/product/B01LXGMP92/?tag=atomicindus08-20
If it did gas also it would be good but more expensive; my main need is for diesel, so this is good. An AC version would be more practical for my need, but again, much more expensive as it is on higher end models costing 3 times the price.
This model states 24 amp needed. So what are my options;
  • A standard car battery hooked up to a battery tender?
  • Would a small U1 battery for garden tractors be sufficient?
  • I have an AC outlet nearby my installation, what inexpensive setups could made
I have looked at AC to DC converter/inverters but they are not cheap when you need 24 amps or higher.
Any other thoughts or ideas on getting a DC powered transfer pump to work inexpensively, would be appreciated.
Shehzada
Don't overthink. A regular car battery is fine.
Sent from my moto g(7) using Tapatalk
ihateminimumwage
F
FMC1959
I've moved a lot of waste oil, diesel and coolant at work with the HF 12v transfer pumps. They have an AC version as well. They include a replacement vane for the pump, but I haven't needed to replace one yet. One nice thing about the 12v is you can swap leads to reverse flow direction.
https://www.harborfreight.com/110-hp-transfer-pump-320-gph-63317.html
https://www.harborfreight.com/12v-dc-transfer-pump-290-gph-63324.html
That's pretty cool, but not something I need. Till the COVID stuff is over, I can't get to the US, thus no Harbor Freight. Besides, these are pumps only, when you add the nozzle, hose, and suction pipe, they are about the price of the Fuelworks I am looking at.....except for the AC powered unit. That is a great price for an AC unit.
**** Just noticed in the description, these are intended for water. You can use them for diesel, but typically not advisable.
