Transfer switch question
williamikerd
I am installing a transfer switch when I get into my main breaker panel. Some of my 20 amp workers have got to block wires hooked to them. If I’m going to use them with my transfer switch I’ll have to take the two black wires out and put one red wire and now I’m left with three black wires to the tire them all together.
nadogail
Coronado, CA
Welcome to the Forum from Southwestern California.
Black is not one of the "Sacred" colors, White and Green are. A Black wire can be extended with a Red, Purple or almost any color except White, Green, or Green with a Yellow Stripe. Orange and Violet colored conductors are often used in special cases.
W
williamikerd
Your answer doesn’t relate to what I was talking about. When you install the transfer switch you take the black hot wire out of each breaker that you want to hook up to your generator and you put the red wire from the transfer switch in where the black wire was then you connect The black wire from the transfer switch to the black hot wire that was connected to the breaker with a twisty on a couple of my breakers. There are two black wires hooked to the 20 amp breakers if I take those loose and install the red hot wire from my transfer switch. I will be left with three black wires . Do I hook all three of them together with a twisty in order to make the right connection for my transfer switch.
nadogail
Coronado, CA
My apologies for answering a question that I did not understand.
PCustoms
VT
Post a pic.
If I am understanding you correctly the red wire goes on the existing breaker, and the 2 wires you took off get connected to the black wire from the transfer switch.
Note: your original post has some typo/autocorrect issues that makes it hard to follow.
W
williamikerd
That is exactly what I’m saying. Am I correct in doing it this way if there was only one black wire connected and I substituted out for a red wire from the transfer switch that I would connect the black wire from the transfer switch and the black wire from the breaker which is normal procedure, but I didn’t know about three wires.
