Transferring 2 Knockouts to a Panel
mobiledynamics
Gotham City
Two KO's I'm transferring from one panel to another.
1" and 1 1/4.
I put the other panel and traced/transferred the holes to where it needs to be on the other panel.
Tools on Hand.
Unitbit
KO Set
Carbide Hole Set.
Making the 1st hole should be okay. I know I can line it up even if I'm off a little bit.
However, bearing 2 holes on the same side of this panel, the tolerances get a little bit more tricky. Much less FUDGE factor.
Any tips you can share
mobiledynamics
Gotham City
Nope. Not enough room to get the hole/drill in if I was just use a hole.
I was leaning on the unibit then the KO - as it's the cleanest cut
I could just unibit the whole thing...but the panels get hot, the cut is not as clean as the KO.....
Mustang51js
Haskell nj
But then again if you can unibit the whole thing then I would do that. I usually run the bit in the opposite side once I'm done to take the burrs out if I can get the drill in there
mobiledynamics
Gotham City
I've used a Unitbit on a similar gauge splice/pull box eons ago and remember going 90% and then doing the other 10% on the side. It was still not as clean as a KO and I spent some time with a round rasp afterwards.
It's tight. Not going to do Uni on the reverse side. Can't fit drill and uni - not enough height.
mobiledynamics
Gotham City
Turned out much easier than I thought.
It's been awhile since I used my KO set.
The KO set I've used recently is self centering....
Mine was not. So I unitbit the stud hold, put the cutter side - lined it up with the traced circles and even with the 6" High Box, I just drew from the inside and VIOLA, much easier than I had expected.
The other 2 holes I made (which I was not lining up, I just used my TKO cutter.
