Transformer Question
WhoWhatNow
Collegeville, PA
What do I have here? This transformer came attached to a Delta tool grinder I just picked up. The tool grinder is 110V 1 phase. I assume this was used to step down 220V 3 phase power to run the grinder. Is that correct?
Jlarson
You've got a pretty beat up single phase step down xformer.
Jlarson
Zooming in on the computer it looks like it was hooked up for 480-120.
nehog
Jaffrey, NH
I did not realize that there was 480v 1 phase.
So, would I have any use for this in my shop? I only have 220v 1 phase.
There is, simply one leg of a 480 three phase supply. I doubt the transformer is needed if you have access to 120 volts with the capacity to supply the needed motor current.
Steve from Socal
Hutchinson Ks.
Your transformer would generally be used as a control transformer on three phase machines. Control voltage is now 24 VAC usually but in the past "low voltage" control systems were 110~120 VAC. The transformer would provide the low voltage without the need for single phase low voltage wiring to the machine.
I have several 1 KVA transformers like yours, for me they are very handy.
Steve
W
WhoWhatNow
Collegeville, PA
That's what I thought. And this is only a step down transformer? I could not use it to step 220 up to 480? You know in case I found a 480v machine that I absolutely had to have..
Norcal
Since your in the USA you have 240 volts not 220, it's more complicated then that when one has a 480V machine and only 240 volt single phase power, a transformer only steps up or steps down the voltage, it does not change from single phase to 3 phase, and does not change the frequency either.
ddawg16
S. California
It's worth about $50 on Fleabay.
In the scope of control transformers, it's kinda small. You will only get about 8.3A out of it (120Vac)
