jacobm99
I fabbed up some transition ramps that will run the length of my garage door which I will be securing with tapcon screws. I coated the underside with chassis saver to prevent rust and will be covering the top with a bed liner product (Monstaliner) after it’s screwed down. Before I install however, I was hoping for some input on the following:
1. I want to put some sort of cement of other form of support in the void marked by the red X in the first picture. My initial thought was some concrete product that I would lay the ramps on top of when wet so that when I screwed the ramps down, the cement would form to the back side of the ramps and harden that way. I wouldn’t put the concrete the entire length, but instead every 6 inches in order to allow the concrete to flow somewhere when being pushed down as the ramps are screwed down.
2. Some of the ramps do not sit perfectly flat on the tile, as indicated by the blue circle in the second picture. This is due to some ramps being bent a little too much. When screwed down, it will only be 1/8th of an inch or so, but I want to fill that void (marked by the blue circle in the second picture) with something. My initial thought was liquid nails- not necessarily for the adhesion, but more for the support it would give when it dried.
3. I want to seal the front and rear edges of each ramp (see the yellow lines in the third picture) with sort of sealant to prevent water from getting underneath the ramps. Not sure what would be best, but I would like something relatively durable.
