Transitioning from NM to surface-mount EMT
exranger06
CT
I'm probably overthinking this, but: I need to transition a NM cable inside a finished wall (drywall) to surface-mounted EMT with THHN wires. One option is to cut in an old-work box and bring the NM into that, and then install an extension ring like this to attach the EMT to:
Or, can I simply drill a hole in the drywall, fish the NM through the hole, and install a cable clamp on the backside of a surface-mounted 4"x4" box?
I'm assuming the second option is fine, and it's the method I would prefer.
Movover
Central Maine
I am sure an sparky will chime in But, I see nothing wrong with the 2nd option. You would have cable clamp and all the connections in a metal box. Looks good from here :)
Bert_
NW Iowa
Cable clamp every time.
The first option would normally be used where there is an existing flush mounted box and you want to extend with surface mounted wiring.
