widetrackman
- Joined
- Feb 26, 2014
- Messages
- 62
NAPA 700 transmission jack made by Sunnex I think; marked 520-4002 leaks down when loaded. No fluid leaks.Replaced piston seal no change. Removed release valve looked ok, but there was no ball in port, is there supposed to be one that goes before the release stem. Also when leaking down pump lever does not move up if check valve was leaking .I can not figure out what to do next.
