Transmission Jack Replacement Arms
crooney1189
Hernando, FL
I have a tall transmission jack like you would use under a lift, but it's missing the 4 arms that would bolt to the corners of the top plate, as well as the safety chains.
Does anyone know where I can buy just the arms as a replacement piece?
Google and Amazon aren't turning up any results, unless I'm missing some key word in the search.
I may end up just buying flat stock to cut, drill and bend up to make them that way. Assumed the actual arms would have been thicker metal than anything the big box stores would have on the shelf though.
whateg01
doo dah, kansas, usa
For $200, I would just make them. Would take about 10 minutes. Ok, maybe 20 because holes. They aren't that thick. Transmissions are not that heavy and they have shape.
