Transmission Jack
02camaro86
New Jersey
you cant con a buddy with some beer and pizza to lend a hand? that transfer case should be manageable for two guys. beer and pizza is alot cheaper.
NOZZLEMAN
San Antonio, TX
I have two NAPA trans jacks, use frequently with no issues. Used on HD truck transmissions and fire truck transfer cases.
Good luck... there is no substitute for a good trans jack, period
malibu101
Walnutport PA
Bash away if you wish, but, I got a HF trans jack that has worked perfectly for the about 6 times I've used it.
Like was said, the jack makes it easier than having 2 guys under there fighting for space and the potential to drop it.
Are you using it "often" or occasionally?
Mark in Indiana
Southern Indiana
Same here. I bought mine to pull a transfer case off of a full size '87 Bronco. I used it for pulling transmissions on my sons' cars over the years. I would have paid 10 times as much for an OTC brand as my HF.
619DioFan
San Diego , Ca.
I was looking at the HF ****** jack last week. I have two HF floor jacks and they work really well. nice to hear positive feed back on the trans jack. will add one to my collection.
sandmanxx
North Pole
Is it a diesel??
350 lbs +.. I have a dodge 5.9 diesel 48RE and "ANY" help from "ANYTHING" that saves your fingers is a plus.. Don't care if u got it from the $1 store.
I don't usually comment anymore on ( - ) post - but.. Well I can't go down that road so to the OP.. Whatever works. :spit:
dalejrfan88
+1 for the harbor frieght jack. My friend bought one about 6 years ago now and we have used that on countless projects. Well worth the money!
Stooge
South Shore, MA
I don't have either, and I realize theres not a lot of deviation with transmission jacks, but they do look remarkably similar and the specs are basically identicle, I wouldn't be surprised if they have the same oem, just one is $150 cheaper
