Transporting air compressor up right?
plain garage
I'm looking to get an IR garagemate 20 gallon vertical unit. Even though its no 80 gallon 2 phase, but its my first oiled compressor. My friend has a Toyota 4 runner, the box will fit laying down but will there cause any problems for the pump? If it has to be transported standing up, I'm going to get a HD truck.
lametec
You can transport it laying down, but make sure you let it sit upright for a few hours before powering up so any oil can return to the crank case.
That's assuming there's oil already in it. If it's dry, then no problem at all.
48RON54
Inland Empire, CA
i transported a tall vertical one on its side about 30 miles each way to/from my work. Only issue was most of the oil drained out of the fill hole while in transport (not sure why i didn't see that coming)
I think you will be fine
A_Pmech
IL
It probably shipped without oil in the crankcase. Confirm that it's empty before putting it in the SUV and you'll be fine.
- Tom -
I have that same model compressor - mine came with no oil in the crankcase. No issue transporting it laying down.
corrie
Def. Make sure the oil is drained. Speaking from experience...
Good luck with your new compressor
