CreteCoater
OK so here is my ride on shot blaster that is in need of some love.
If you look at the wheels you can see they are steel. The old rubber got brittle and came off in chunks. I need some traction to drive into the trailer and a smoother ride.
After googling to find new wheels I see how expensive these bastards are. The two back ones are keyed drive wheels. The front isn't as expensive but I can still think of better things to spend money on.
I decided to see if there is any way of re treading what I have and after an hour in Lowes I came up with this.
I plan on cutting the rubber to size, epoxying it to the rim, and adding some steel pop rivets deep in the grooves.
Anyone have an idea how to cut the rubber in 3" strips cleanly without looking like a hack job? It is about 3/4" thick and made from recycled tires. Will a table saw work or will it bind the blade?
Sent from my DROID RAZR HD using Tapatalk
