Treating rust and applying paint
PopPops
CT
I have a pair of large unpainted car ramps that have surface rust on them. I would like to clean them up and paint them with a good quality paint that would not scratch easily. My plan is to have wire brush them then power wash them and let them dry before applying a Rust Reformer followed by brush on paint.
My question for you guys that have done this is, does this plan sound good and what have you used for neutralizing rust and a cover paint?
nadogail
Coronado, CA
Powder Coating is the most durable way I know to protect your ramps.
Wire Brushing, Power Washing and Rust Converter before a careful application of Oil Based Paint would be my lesser desired option.
kerrynzl
Tauranga, New Zealand
Get them sandblasted then powder coat them.
Get them "Hot Dipped Galvanised"
Sand Blasting is not needed.............But they need to be oil free
Terra Nova
Or use some POR15 paint with a topcoat. Don't have to get too carried away with removing the rust, it's actually better if you don't.
Walkers
Cave Creek Az
Powder coating for ramps is way overboard, probably cost more than the ramps. Wire brush and clean them up, then hit them with some sandpaper. A DA would be great, but hand sanding is fine. The wire brush just leaves them a little too smooth for paint to stick well
Kuma601
Cali
I'd take the cheapest easiest route. Now if these are nice ramps and you want some sort of discussion piece then go all out. If you know somebody that has a media cabinet that fits them, blasting is easy then painting. I've used the random orbital sander then rattle canned stuff.
rockettauto
Basically anything of decent quality is going to cost more than the ramps.
That said you can't really buy ramps that I know of with a good coating.
That said I'd probably get some two part urethane bedliner like a raptor kit. Use the rest for other stuff.
mark-NJ
new jersey
These are car ramps! Hit the rust spot(s) with some sandpaper, get the rust off, clean with naphtha, then acetone, then hit it with some rust-oleum. Done.
