Fredro Starr
Quick question for you experts about tree removal.
Having to remove several trees for my build. I am getting conflicting opinions. One contractor wishes to cut the trees and use a bulldozer to take the roots from the ground because he says eventually they will deteriorate and cause the concrete pad to crack/settle. The majority wish to cut the trees and grind them down 18 inches below the surface and they say that will be adequate for the concrete pad. Obviously option A is the more expensive option.
Any thoughts?
Thanks in advance
Any thoughts?
Thanks in advance
