Tri Wing nut Socket
YoshiMoshi3
I have a tri Wing nut that is meant to be turned by hand, however it is rusted to much to unfasten by hand. Had been sitting outside for to long. Is there a socket for this type of fastener? It appears to be a wing every 60 degrees. Something like this
This isn't the exact but but to just illustrate what I'm talking about. When I look for Wing nut socket all I can find is the socket with either two or four slots in it for a twin wing nut type of fastener like this
Is there a socket tool to aid in fastening and unfastening a tri Wing nut with three wings instead of two or four wings?
YesIHaveAHammer
There won't be a socket for it.
Perhaps make something with some blocks of wood on a board, put a bolt/nut in it to put a hex socket on it.
I have this oil filter grabber that I'd be tempted to offer it up to and see how it fits.
KnurledNut
n/a
Thats the spinner nut to retain the wheel on a AC Cobra. Did you finally trade in your Acura? :bounce:
A lead hammer is the go-to for knock off spinners.
But specialty tools do exist for the application:
Also be aware they are right and left threaded.
f121
UK
Ahh cobra, I was thinking Jaguar!
There are socket/torque wrench adaptors for knock off spinners:
Think you might have found the issue 😂
Shadowdog500
Down the shore
+1 on a hammer. That is the way knockoffs were usually removed and installed.
Here is an older Jaguar tool set shown on the Moss Motors Page.
#36 is the copper/rawhide hammer used on the knockoffs.
Stubby1743
UK
The OP posted the picture of the Cobra KO wheel nut just as an example of the sort of three lobed fastener that he was talking about. I suspect that his actual fastener is a lot smaller. :)
Shadowdog500
Down the shore
Are you talking about one of these tri-bar wing nuts that people sometimes use on an air cleaner?
Drive 3 nails into a 2x4 120° apart and use it as a wrench. Put vacuum line over the nails if you don’t want to scratch the part
Zewnten
I would guess that that knockoff is super expensive. I would do anything before that.
I would definitely recommend figuring out the correct thread directions.
This poster always wants an engineered solution to minor problems. I'd be willing to bet the nut he's working with is nothing like the poster other than the general shape. Did you miss the part about rust? Generally people don't leave high end items outside to corrode to the point they can't get them loose with a little elbow grease.
neophyte
Pennsylvannia
To be fair, dometimes there are “”engineered solutions” to certain problems, that the average person, or even people in the particular field, are unaware of, that can make a job that otherwise might take over an hour or more, with damage, take a few minutes with practically no damage.
As far as not leaving items outside to corrode, that routinely happens, as does not using precautionary measures like anti-seize.
Even manufacturers routinely skip grease or thread locker.
claymont
CLAYMONT, DE
About a 2 or 3 pound soft faced hammer and a rust penetrant and maybe some heat.
Leaflessshadetree
Don't ask.
If it's a lot smaller. Maybe one of those gimic "one size fits all" sockets with spring mounted pins in it. (Usually sold just before father's day or Christmas).
I've heard guys like them for wing nuts. I wouldn't a third wing to be much different.
