Trick for two RH bolts in threaded hub?
ChevyEFI
Phoenix, AZ
I bet there is a neat trick or tool for this. :bounce:
I'm just trying to get both axle bolts out of the bearing hub sleeves. The bearings are ABEC-7, so when one is out, the other does not unthread; it just spins the bearing.
Punch the end of the hub sleeve and use a pick to hold it from rotating?
Will check back in . . . :beer:
C
ChevyEFI
Phoenix, AZ
A pick, inserted into one side of the hub, jammed against the side, lets the other side be removed with an impact driver.
