Jon_E
I've started wiring my shop and ran into a little problem over the weekend. I started by installing a double duplex receptacle (120V) and a single 240V receptacle adjacent to my panel. I am using surface mounted square boxes, EMT conduit and #12 THHN stranded wire. I have a bunch of older receptacles, none of which have the backwire feature (not the stab-type, I won't use them), but they all have regular wire-mounting screw terminals. I found that no matter what I did, I could not get a clean-looking connection between the stranded wire and the screw terminal. I think I did OK after a few failed/aborted attempts but I don't like it at all. I don't have any solid wire to run pigtails, either. I never considered how difficult this would be, as I have never used stranded wire in line-voltage circuits before. My entire house is NM-B (Romex) and it is all solid wire.
Any special tricks or tips to using stranded wire on receptacles and switches that have screw terminals, or should I just set these aside for use in solid-wire circuits and buy some new commercial-grade receptacles with backwire plates?
