gft
Hi everyone. I posted this on another forum but thought of the vast wisdom you guys possess. I'm needing to drill 3-1/4" hole into side of 24" diameter plastic drum off center (not square to side of drum). I've put a longer pilot bit on but think a little less than half of teeth will be all the way through before the rest contact the surface. Has anyone done anything like this? Thinking maybe attach block of wood on inside to keep pilot bit and hole saw teeth boring. I'm inserting 3" pipe into opening, coming into it at an angle with resulting hole somewhat egg shaped. Thanks for any insight or ideas.
