mrholeshot
MEMBER EMERITUS
- Joined
- Jun 22, 2010
- Messages
- 8,043
Thinking about a question from this morning about American built wrench sets there is one wrench that hasn't changed much over all the years I've around the blue marble and is still one of the best values going. The Craftsman raised panel wrench. Still made in the US, still a very solid performer. Here is a set of wrenches you can own and if you buy in the 43 pc set includes everything from 1/4 inch to 1 5/16 and 6mm to 32mm all for around 150-175 dollars depending on when you buy and no ignition wrenches in that bunch. Despite there being slightly better designs the craftsman raised panel is still a sodid performer. Before I wrote this I took a new one that had never been used (9/16) that came in a set and took it out into the garage and hooked it on a well used 3/8 nut and bolt that I put through my drill press plate. I proceeded to tighten the nut until I could no longer pull anymore so I hook another wrench to the open end and pulled until the bolt snapped. The nut and bolt wern't new but rather a collector bolt that had been installed and removed around 5-6 times. It didn't round the nut depite in not having flank drive. It would cost you over 1000 dollars to buy that set off any tool truck all the way into the larger wrenches. They are just no nonsence, no fluff solid performers that haven changed much over 50 years. maybe it's time to get back to the basics.
