goldie lox
- Joined
- Feb 12, 2015
- Messages
- 142
i want to install a 240v welder, so neighbor said he had some wire here it was triflex. it would be run overhead with an outlet high up what are your thoughts about using it
So what happened ? Don't keep us in suspence!Triplex is not even a recognized wiring method/ material by the NEC, nothing good comes out of using it indoors, a scary thought: There is a home in Northern Arkansas where they used triplex in steel studs to feed a subpanel.Note, there is no inspections where it was built other then septic systems.
The town of 50 my dad lives in in nw Arkansas has all kinds of county inspectors.
These guys can get your project sorted for you, but you need to provide more details...
How far is the overhead run?
Do you want to follow code? Be safe but not follow code? Just weld?
Where is this terminating? A building? is there electric in it? Do you want service in it?
Maybe run the triplex over head sau 140 feet to the barn, then a service head 30 feet down to a small 60Amp subpanel- run a 240V welder receptacle and a 20A light and receptacle circuit. Maybe 2-300 for parts? just waging.
It sounded to me like he wants to run the triplex indoors...
I have a 50x60 garage with a 200a service. I was thinking of running this from the panel overhead about 40ft away and termination in a recp. above head.
