pharper
I just finished drywall in my garage workshop. I replaced the drywall on two walls so I could insulate, install electrical, etc. The garage door wall and the wall attached to the house were left untouched. I am installing exterior grade PVC base trim and had a few questions regarding paint an order of operations.
1) Will the PVC trim take paint like any other trim? Should I even bother painting it at all, since it will be painted white?
2) Should I prime/paint the walls before even installing the trim? I'm using small bed trim at the ceiling and the roller likely wouldn't reach into the corners close enough. I don't mind cutting in, but it might take more time.
3) I was planning on doing a light grey on the walls. Any suggestions? I've read some tests where good paint/primer all in ones were doing better than even the best separate primers and paints. Both required about the same number of coats, but the all-in-ones had better adhesion and sheen retention.
Any other suggestions would be greatly appreciated.
