Kin Creed
I was using a big router to cut out a design on an oak plaque with a template and that worked great.
I also wanted to edge the plaque with an ogee bit and I have to make at least seven of these plaques so to save time I thought I would just use the trim router instead changing bits on the big router.
Well using a trim router to cut an ogee on an oak board works, but it's a bit sketchy. The oak is pretty tough and the trim router is so light I felt the tool wanting to torque out of my hand a few times. Also, I was routing against the rotation for the most part (of course) but there were a few sections where the piece was clamped it was easier to rout with the rotation for a short length and that was crazy. The little router grabbed the oak and went for a quick ride down the edge!
I used to view the big router as more dangerous than the little router but now I've changed my mind. The big router is heavy with big handles and does not get away from you as easy, especially in hard wood.
The trim router is pretty much a one handed machine by design, but it still packs plenty of power. And cutting away significant material in hard wood is stressing it limits, especially on the control side.
I will probably still use the trim router to finish the rest of the plaque edges, but I'm going to be much more careful. However I am thinking a small router doing a bigger job like this is inherently unsafe. The trim router seems too light and unstable for this type of work.
Has anyone had similar experiences using a trim router? I don't want to be changing bits all the time, so maybe I'll just need to finish all the template work then edge all the plaques with the big router.
Anyway, that little trim router has been great for soft woods like pine, but in a hard wood it really got a bit freaky!
