Trim work question
shamus29
Hey guys drywall should be finished up today for my garage. Starting the paint and trim work over Christmas, and I’m curious what do people do when they have a 6 inch curb around the bottom of their garage.
casmurbax
Wilton, NY
Are you talking about, that you have a 6inch high block and then your walls are built on top of that?
Kaizen
New England
I painted mine the same color as the wall. Mine is a foot high. Pita due to divots and crevices in concrete. Used a brush and pushed it in where roller did not reach
Shiftless
East Bay SFO
That’s the way I would do it.
If you’re fussy, you could parge coat the “curb” with mortar to smooth it out a bit. But then you have to be careful and mask the floor, give time to let it cure before painting, etc.
I’ve seen guys with painted floors paint the curb the same color as the floor.
glentre
Gloucester, Virginia
Best to leave the drywall slightly elevated from the curb if you expect to be washing cars in the garage. Either way, run some 3/4" quarter round to hide the joint between the drywall and curb, caulk if necessary and then paint.
Glen
gsmith22
Central NJ
if you are going to paint masonry block, it should be primed with "block filler" to help smooth out the surface and prepare for top coat of paint. otherwise you are wasting your time
