Trinity replacement 5"x2" caster wheels
roadrunner255
Driftwood, Texas
I have 2 trinity 6' rolling ss tool storage boxes with wood top where the caster outer rubber has cracked off and I'm searching for replacement casters .
Don't want to use their replacement casters, anyone do this?
Specs say tool box weight is 2200lbs.
Thanks
tool_scrounge
Southern California
Looks like standard 5x2 caster mounting plate dimensions.
Do you just want to replace the wheels or the whole caster assy?
example
https://www.ebay.com/itm/121476522083
I prefer phenolic wheels are they are really indestructible and do not shed their treads like the 2 piece molded ones. But I am not rolling my tool box around all day.
I usually by NOS or new name brand (Colson, Albion, etc) casters off of eBay for cheap. I usually use 1000 lb. capacity casters.
Bondo
Greenfield, Maine
Thanks
Ayuh,..... Look in Surplus Center, com,....
Lynden
Southern California
I have 2 trinity 6' rolling ss tool storage boxes with wood top where the caster outer rubber has cracked off and I'm searching for replacement casters .Don't want to use their replacement casters, anyone do this? Specs say tool box weight is 2200lbs.
Zoro.com has a large selection of replacement caster wheels in addition to complete casters, plus they have excellent specs for each wheel and caster so you really know what you're buying.
nadogail
Coronado, CA
I typically get my replacement casters from Harbor Freight. They might be an exact match but I can generally find replacements that are “close enough “
