75gmck25
I have a five year old Buderus GC-124 gas boiler for my radiator hydronic heating, and it has an intermittent problem with starting up and running. It failed to heat up properly once last year, and happened again this morning.
This morning I found the pump running, but pumping water at about 100 degrees instead of the normal 135-140 degrees, since there was no flame. I turned the off the power at the local shutoff switch, turned it on again, and the boiler started up normally. However, the flame went out about 30 minutes later, before house temp got up to normal. I cycled power twice again before the flame started, and its running now, but I'm not sure it will keep running.
The boiler is pilot-less ignition, so I know there is a startup sequence and sensors that work when getting the flame going, and I believe there is also a sensor to ensure the electric flue damper is open (it was open, and I can watch the actuator move as the system starts up).
Anyone have any idea of what typically gets "tired" or dirty on this system and causes the burner to shut down? I originally thought it was failing to start, but now that I know it shuts down while running, there may be a problem with a sensor that operates when its already running. I can try disassembling the burner and cleaning everything, but that's a lot of time spent just for a shot in the dark.
I have a maintenance contract with a local company, and they will be here this afternoon. However, the guy they sent out the last time did not have experience with this specific brand/model, so the troubleshooting was very limited once it started up normally.
Thanks,
Bruce
Thanks,
Bruce
