Truck Frame Welding
Fastfish
North Central MA
My Brother inlaw has a work van that has some big rust holes in the frame. (GMC full size van) I just welded some mild steel (3/16) plates over the holes. used a Mig 175 with flux core mild steel wire. (I can weld ok) .Question is, was this a bad thing to do interms of creating stress concentrations around the welds? Thanks.
Mr.N
Mpls, MN
Make sure what your welding to is solid
Don't expect the patches to last much longer, its rusting for a reason and it will continue. Expect there to be other areas that will need repair once you start looking.
F
Fastfish
North Central MA
Re: Truck Frame Welding - Thank you and another question
Thank you to all who replied. I was really worried for a while. I will be sure and check the frame out next time my bro inlaw comes over. I plan to do more of this in the future and possibly build an ice race car. I need a plasma cutter next to make gussets and other brackets...... Question is: does a plasma cutter leave an edge like oxy/acc cut? is it more or less rough? Thank you
CNGsaves
KS and OK
Really depends on the vehicle . . .
If the van looks like pic below, then tell BIL that van is unsafe. You'd be more than happy to take off his hands for $1K and fix frame properly ! :D
Then get busy welding to box the whole frame !! Problem solved. :evil:
creativecars
Indiana- where horse and buggies still roam
A plasma will cut as smooth as your hand can move. And leave just a bit of slag on the back side. One quick swipe of a grinder and it is gone... So much smother than a oxy/acc for me. But there are some guys that are "good" with a torch and can cut almost as nice as a plasma. :thumbup: That is not me.:beer: I just cut and grind.
MoonRise
Generally, an air-plasma cut on mild steel will have a significantly smaller HAZ than an oxy-fuel cutting torch on the same mild steel, due to the faster travel speed of the plasma and no pre-heat flame like the oxy-fuel cutter has.
The cut-edge quality can be as-good or better than an oxy-fuel cut edge. If the amps and travel speed are set 'appropriately' for the metal thickness, plasma can usually leave a cut edge with just a tiny bit of easily removed dross on the 'back' of the edge.
A bit operator-skill dependent though. :D
