jaybird3897
- Joined
- Dec 22, 2011
- Messages
- 23
Can I mix 2x6 and 2x4 bottom cords without issues as long as pitch is the same? I plan on using half scissor trusses with 2x4 bc and half storage trusses with 2x6 bc on a 30x48x10.
You can use whatever you want as long as its designed to carry the load.
Sorry, what I meant was by mixing different sized base chords will my top rafters still come out even for putting on roof as long as pitch is the same?
I'm guessing the difference in the height of the bottom chords would be taken up inside the truss structure, not added to the bottom, but that's just a guess. You need to check:
IF the roof pitch is the same AND the height of the roof above the point where the trusses sit on the wall is the same, yes. You'll have to look carefully and measure scale drawings or measure the actual trusses...
One thing to consider is to use 19 5/8 spacing of the trusses to give ...
Sorry, what I meant was by mixing different sized base cords will my top rafters still come out even for putting on roof as long as pitch is the same?
Just tell the truss manufacture what you are looking for, they will set them up to do what you want.
