lojim
Let me first say 'yes I know I could take some plans to an engineer to get them certified.' However, I'm attempting to keep costs down as much as possible AND it's NOT required for what I plan to build. I'm really looking for input from those that know construction.
So I'm in need of some help. I want to see if this is a good structure for a truss or not. If it matters, I am in the Poconos of PA. I have compared many different designs of trusses and combined them to make something that hopefully will work for me. First, the specs:
2x8x10 for 'lower' roof
2x8x12 for 'upper' roof
2x6x~6 for vertical 'hip roof' support
2x4x~5 for diagonal roof support
2x8 for vertical on lower section and overhang
2x8 for truss support and span (3 2x8x12 - 2 **** joints and 1 with 6' overlap on both boards which is not pictured)
Overall roof height is 14' with 24' span between posts (the black boxes at the bottom of the picture).That truss will span between both vertical 'hip roof' supports.
All joints will be reinforced with 1/2" plywood plates that are glued and screwed.
12' wide 'loft' will be left for storage that may or not be used that often.
Barns are constructed 4' on center for these style roofs - I figured that would work fine for my needs also or should they be closer? If I go with this design I would use 2x4 perlins 4' on center to attach metal roofing.
Sorry if my terminology is incorrect - it all makes sense to me.
Anyone know structure and will this work or how should it be modified?
