Strouty
I have a standard roof truss with the "w" web that has 2x6 top and bottom chord with 2x4 webs. The span is a little weird, I had 2x4 walls, then added another 2x4 wall inside that. So I am not sure if it changes my bearing area or not. The span was 30' before we added the interior 2x4 wall. The trusses are 24" OC and I would like to change the ceiling profile from flat to a box style. This would be used to gain height for a second level. I am thinking of boxing both sides with plywood, at this point I have talked with two engineers and both do not like anything to do with modifying trusses, one has given advice, but will not do a design. I am going to call a local truss manufacturer and see what they say, I figure it will be do to blah blah blah we can't help you. Has anyone had any experience doing this or something like it? I don't want to cut anything until I have a safe design and plan of action. I could not get actual pictures, my camera focused on all the freaking dust from the insulation instead of the trusses.
