Truss modification tie plate prong vs. nail/screw
fairlaniac
Denver, PA
I hired an engineer to engineer a truss solution in my garage. I need one truss modified so that I can raise my 4 post lift. The filed engineering drawings call for Mitek tie plates. The prong type. The engineer indicated to me that he has the proper press to press the plates for $250/day rent. I have 10 connection points, 20 total plates. For numerous reasons I don't want to rent the press. Is there any reason why I could not get some plates with just holes and use screws? I see Simpson has some SD screws. The engineer wants me to use the Mitek and press.
Next, who has 8x10 plates without prongs? Then if I find plates, how many holes/screws do you use?
thanks,
strutaeng
Dallas, TX
Talk to your engineer and communicate your situation. Ask him is there's an alternative. He may have something he's used in the part.
If necessary, ask for an email confirmation of the substitute for everyone's records.
TRWham
East Cobb County, Georgia
You are hostage to whatever the engineer calls out. There may be valid alternatives, but if what you install does not match what is in the letter, and the AHJ sees it, then you should fail. We ask the engineer we work with to revise details all the time, but he works for us frequently.
I will add that connections are not trivial. I recall doing a problem in school where simply adding bolts to one side of a bracket caused the other side to fail because the difference in deflection caused enough difference in stress to overload one side.
Half-fast eddie
Virginia
I agree you’re stuck with using standard pronged plates, because they have been tested and the performance is known. So the question is … can you install them without his device? Zeke might be on the right track … cobble together a hydraulic jig. Or ask the engineer if you can substitute heavy gauge drilled steel plates with structural screws or bolts.
Trapps
The Detroit Zoo
I wonder if your engineer has some incentive to use Mitek.
Alternatives in addition to Simpson:
Eagle
Alpine
Another alternative is plywood gusset plates. However, an engineer would need to prescribe the thickness and grade of ply as well as the fasteners (screws or nails) and their schedule.
Walkers
Cave Creek Az
For $250 just rent the machine and be done with it.
if you don’t want to rent the machine then cobble an alternative with a hydraulic jack.
jack stand
Lakes Region Maine
I also find it "funny" that your engineer happens to rent the plate press. Surely 3/4" plywood on both sides of the whole friggin truss would be stronger just glued and nailed let alone screwed.
bluedog225
Texas
A little weird for the engineer to have the equipment he is specifying. Bit of a conflict. But at $250, no big deal.
F
fairlaniac
Denver, PA
$250/day and he's a 90 minute drive. I figure I might need it over two days just because of travel and doing the labor. I'm a mechanical engineer by trade, not a truss builder so I'd be taking my time not to screw things up. So it's a minimum of 6 hours travel in a day to try it all in a day. So I'm looking at $500. Decisions.....................
Walkers
Cave Creek Az
Have you checked to see if you could rent it locally? Ask him if you can return it the next day. It is only one truss, so I just don’t see how that is going to take you all day.
