Truss/Sheating question
feotto
Hi, I have some help coming tomorrow with intent to fly trusses. Today I only got two sides of a 26' x 26' 11' walls garage sheathed. Is it OK to go ahead and get trusses up with right side not sheathed, and sheath it after they're up, or maybe get 2-3 sheet up to help stabilize the wall before trusses?
F
feotto
You need to sheet that wall. At the very least put some diagonal braces on. The front wall could use some more shear also.
I do have diagonal bracing on right wall (look at truck roof) but not really long enough to hand my hat on, and would add another to right side of that wall. I agree more is needed and maybe put up 3 more sheets and get more of front wall completed. Thanks for the advice.
Codyboy
S.E. TEXAS
This. You don't want the framing moving at all.
You and friends that are helping with trusses could put up at least the corner sheathing in a few minutes.
F
feotto
Yes, that's what I plan to do. Putting up 3 sheets and another diagonal brace. Walls are already plumb and braced all corners.
PopcornSutton
Northern Tip of VA
Diagonal braces on the inside of the framed unsheathed wall. Install a brace in the middle of the length on both sides to insure the wall stays straight will getting the trusses on top. Very easy to bump the wall out of alignment mid span.
PCustoms
VT
x#? It needs to be fully sheathed, plumb, square etc. before adding trusses.
Too late now but way easier to sheath the wall and tip it up IMHO.
mike93lx
Richmond, VA
At the day job, we fully sheath the gable trusses while on the ground, apply Tyvek, and even build the ladder framed soffit and trim it out before craning it up into position.
I'd really like to try this on my next build. I've seen videos from a builder in the PNW (awesome framers) where they even trim and side before standing tall walls.
larry4406
Northern Virginia
As a general practice, we never install siding until after house/structure has had its drywall installed. The structure moves slightly with the weight of the drywall.
I have done it per office direction with vinyl siding. We had to redo a couple sections of siding after the house was hung as the vinyl showed ripples in a couple locations. I have also done it per office direction with Hardy siding with no ill effects visible.
mike93lx
Richmond, VA
Seems like they don't side on most builds, but this is one I could find. Not a huge wall.
ddurrett896
VA
This is the way unless you like handing off a gable 20' from the ground.
jack stand
Lakes Region Maine
It might be too late, but diagonally squaring up the top of your walls should be done.
Just because you're level says each walk is plumb....
This can be a problem with truss layout and having the sheathing fall where there's a truss under the seam.
F
feotto
So, had a 3 person Amish crew out this after who got the roof up/sheathed in about 4 hours. Knew I was in over my head after sheathing 11' walls. They lifted up trussed by hand (one person pushed up to two working top plate, and sheathed gables after flying them. Best $2k I've spent.
TRWham
East Cobb County, Georgia
I'm not sure you meet the minimum braced wall panel requirements. We always use the portal framing method (CS-PF) around garage doors. You only need to extend the header(s) a few feet, so it adds nearly no material, but offers sufficient shear resistance with less braced wall panel length.
ddurrett896
VA
I've always done a double LVL across the entire garage and it's always rock solid - cost is negligible.
PCustoms
VT
IRC does not allow a header longer than 18’. If 2 doors, it usually requires 2 separate headers.
So IRC disallows 18' single garage doors?
Hint: I don't think the IRC specifies the header length
TRWham
Read the code and be enlightened.
ETA:
Now that I have a minute more: the longest finished opening allowed is 18 feet, so an 18' door is fine. You also cannot have more than one finished opening within a single portal frame, so even 2 single 8' doors could not be accommodated by one 18' opening. When the standard was set based on APA testing, they only tested up to an 18' opening, so that is still the limit.
PCustoms
VT
I did, your original statement was incorrect.
ETA:
whateg01
doo dah, kansas, usa
Back when I built houses in the mid90s, that's h how we built houses. Wall was pretty much complete before being stood up. Especially nice on the 2nd and 3rd stories.
F
feotto
That's exactly what the Amish crew did. Used my 14' 2x6's. Rafter tails are straight as an arrow.
kwb
PNW
Whenever I see a stick frame erected without sheeting I have to wonder why the people doing it like to make a job harder on themselves?
We fully sheated my 42x14' walls and I even caulked the nail heads for the part of the wall that was done in T1-11. 5 amateur crew and we had all 5 wall segments standing in a weekend.
CraigStu
Blacksburg, Va
Because 2 old guys can easily lift a single 4x8 or 4x10 or even a 4x12 sheet of whatever. But they can't stand up a wall w/ 3-5 sheets on it.
kwb
PNW
I used rope, a couple 2x6's and a truck.
If you get nervous about the size you can always do the wall in a couple sections.
If I was building again I would have a forklift or telehandler on site for a week or so.
Beamer
Northeast
Careful bracing the trusses while in progress.
My neighbor's came crashing down when the carpenters didn't think it was an important part of erection.
cpakalolo
Some people say to sheath before trusses. You don't have to. You can brace the structure and space the tails on one side to accept the sheathing. Try to line up the trusses to only one side and then use the trusses on the opposite wall to line up the wall itself. Just don't give to one side and then give to the other or you will love installing your soffit boards. It is easier and better to wait until the sheathing is on, but you will not have to fuss much at all doing it your intended way. So, fly those trusses!
