Truss spacing
Daddydavesr86
Versailles ky
20x24x10 pole barn style.
Is 5' truss spacing ok?
How do verify that truss spacing is sufficient for area being built? Lexington Kentucky
Im trying not to bug the building inspector on ever little thing.
Thank you
finn
The UP, God's country
Call the truss manufacturer. He needs to know the snow load requirements for your area, among other things.
Your county typically would have code information online.
mitusa
SW Oklahoma
are you using 2x4 for sheeting???
We used to use 40" spacing for pole barns with 2x4 sheeting and a metal roof.
I would think your roof slope would play into the correct answer.....
readhead
Durango, Co.
Truss design will vary depending on tributary loads such as sheeting vs purlins or metal vs shingles. Wind load will also play a part. Will there be any collateral loads? Don’t you
have plans that already lay all of this out?
D
Daddydavesr86
Versailles ky
4/12 roof pitch.
Perlins 2 foot center 2x4.
Metal roof.
Not sure about wind loads. But the code pdf does have a section for wind load i noticed when i was looking up snow load.
No plans. Friend of a friend builds them.
He is Coming by house to discuss in a few days.
He mention truss were 5 foot apart in messeage back and forth.
I thought odd measurement.
Maybe 4' assume 2' spacing.
finn
4/12 roof pitch.
Metal roof.
Residential trusses are designed differently than pole barn trusses. Go to the truss manufacturer’s web site if for some reason you don’t want to call them.
For example, the Menards site will have a pdf link that shows at least some of the design specs. I believe there is also a design link where you input span, Snow loads, etc.
NUTTSGT
Northern Central Ohio
Is the friend of a friend, a truss builder or just happens to build them in his shop ?
If he's a truss builder, he should have an engineer designing them or a program to design them.
The other guy, a hack with a hammer ? Winging it ?
NUTTSGT
Yes, Menard's website has that. I used that and it gave me a print of the specs for the trusses. Both center and end trusses. I built mine per their spec for my addition.
joe_padavano
Northern VA
Truss spacing can be whatever the trusses, the supporting walls, the foundation, and the roof deck is designed for. I've seen Ag buildings with 8 ft truss spacing. The trusses need to be designed for that. The poles need to be designed for that. The purlins need to be designed for that. The fact that you are asking this question without having that info means that you need to consult an engineer and/or the truss manufacturer, not the interwebs.
Augus7us
Central Ohio
My pole barn truses are 4' on center. Don't do it if you plan on insulating and putting up ceiling tiles. Makes it a pain in the ***, wish they were 2' on center...
Bert_
NW Iowa
4' is fine for a ceiling and insulation. Tin will span 4' no problem. I know guys with trusses on 2 ft centers that only screwed the ceiling to every other truss.
renloy
I just installed a ceiling and insulation in a building with 4ft oc trusses and can confirm that the 3' ribbed metal panels are plenty strong enough.
D
Daddydavesr86
Versailles ky
Thank you all for your post.
I will just ask if he is ordering pre built truss or building his self.
I guess i was more or less looking for a way to verify truss spacing is ok.
manwithtools
Lebanon, TN
Trusses in my last homes pole building were 10' on center. Only 5 of them on a 30' x 40' Purlins were 2 - 2x4's assembled into a tee shape. They were pretty heavily built trusses. Truss design is very application specific.
rburke65
Canfield, Ohio
4’ on center for pole barns is fine.....ac+or ding to who? Where? Ceiling? I had a bid and 5he builder wanted a post and a truss every 12’!!! I couldn’t hang up on him fast enough. Go with 2’ on center .....you won’t be sorry
Augus7us
Central Ohio
Yeah, I never said it wasn't possible. I'm putting tin and blown in on my 4' oc ceiling now. I'm just saying its a pain in the *** and I don't want to get up there on rat runs. I'll hire out the blown in for that reason.
Plus all trusses are not equal. In the OP's case he can specify 4' oc and get proper live/dead loads for his ceiling and insulation. Per the folks here if you do not have paperwork, then your trusses could be rated at 0 ll/dd.
So if you are hiring it out and you're going to button up the ceiling never to go up there again. 4' oc is probably fine. All depends on what you expect. If you're in Alaska and need 6 feet of blown in, I wouldn't do 4' trusses. My take anyway.
greg13
Weedsport, NY
Truss manufacturer has all the specs and engineering data. Mine came with a 6 page data & placement manual and load data.
