Trying to open air handler... Little help?
Mandres
Hey fellas,
Hoping someone can help me with this. We have an older trane central ac in the rental house and I'm trying to get access to the A coil to clean it out and investigate some moisture issues.
I'm not able to remove the cover from the air handler - all the screws are out but the lineset passes through the panel and prevents it from lifting away. Other units I've worked on the lines pass through in a spot separate from the main access panel, but not here. Should I take a cut off wheel to the panel and cut out where the lines pass through? How would you seal that back up if so?
Thx!
