I am new at using/installing compressed air systems, so bear with me on this. I understand that the system should have a downhill tilt to it and the drains be placed at that point. Makes sense to me.
However, Here is what I have to work with.
My compressor, an Eaton 5hp, 60 gal unit will be in an out building about 90' from the garage and 300' to a well. The unit will be providing air for my soon to be shop/garage as well as an air operated well pump (more on that if you are interested). Both the well line and shop line will be underground.
The run to the well is 300' and is downhill so I plan to put an air filter with and automatic drain at the point the pipe comes into the well house and then elbow up a few feet to a quick-disconnect for the line going down the well. This should take care of the line drain in this direction.
To the shop, the line is uphill, maybe a few feet. So where to drain the line. The low point will be in the out building where the line goes underground only a few feet from the compressor.
So, would another air filter with an auto drain be useful at this position, or just put it at the working end in the shop? The later would be after the pipe comes out of the ground and up a few feet just before a quick disconnect port.
I read somewhere about building a cooling column on the wall and letting it drain back into the receiver. Would this be a better solution?
Thanks...Bill
Thanks...Bill
..stevo
