joshboogie
OK I know pretty much zero about anything electrical outside of a car so can someone help me to understand what I'm looking at in these pics?
I'm trying to figure out if it's possible to tap into any of this to run an outlet for a few small battery chargers and a drop light.
From reading I know that Black and Red are Hot, white is neutral, and the bare wire is the ground. Now the black wire from the ballast box is tied to the red wire which has 120v with the switch turned on and goes dead when the switch is off. At the switch itself there is a black wire, red wire, and a ground. I'm assuming the red wire at the switch is also the wire at the light itself because they both go dead white the light off. I originally wanted to take power right from the switch itself but there is no neutral so that was out. The only white wire I see at the light appears to be running straight from the socket into the wall. Is this neutral? It never has power on it.
I'm new to the 110+ volt world so sorry if this seems all jumbled together.
