Trying to use dead space
PapaBuilds
I have a small 2 car garage work shop, I do a bit of everything so I'm trying to make full use of every inch for storage and infrastructure. I decided to put a french cleat wall next to the stairs so it wasn't just dead space.
I'm trying to hang mostly shallow/ thin things on it so it doesn't choke up the walk way and annoy us (my wife especially). I've whipped up just a few tool holders today.
To save 3/4 of an inch of stick out, I'm mounting the holders and brackets directly to the french cleats and using a locking block pressed in above it to keep them from shearing/popping out. I'll update with another picture of it when its full!
Codyboy
S.E. TEXAS
Is the notched / angle suppose to go on top or bottom like you have it?
What keeps it from pulling the bracket / hanger away?
P
PapaBuilds
I don't know how familiar you are with french cleats but the two 45 degree angles meet when you slide a holder in, so down. It holds snugly and you have to lift it up to remove it. The locking block I put on top prevents it from raising at all so it can't slide out.
PCustoms
VT
I really don't see how that locks anything in place.
Can't your "locking block" just pop up/out?
P
PapaBuilds
You would think, but I cranked on it pretty hard. It ain't coming out. Besides, it's light duty. I don't need it to hold 1000 lbs.
PCustoms
VT
Also the 45 degree cleats are fitted together, these photos may help.
Much better.
Before the bottom of the top clear looked to be cut 45 as well, which just seemed prone to popping out
This one looks like a 3/4x3/4 block jammed in square, makes more sense
driftpin
I like your idea, and second the attempt to prevent the wife from barking her elbows on whatever's hanging.
I have Whirlpool Corp./Gladiator french cleats I got w/welded wall-mount cabinets. I just screwed the 12" deep steel cabinets to the CBS wall using tapcons and fender washers. Above the 2' x 8' workbench, w/a 3/16" steel top above a 3/4" plywood cabinet top, I mounted the french cleats to hold a variety of tools including cordless tools battery chargers. Handy Lift.01.jpg
PopcornSutton
Northern Tip of VA
Those cleats are used often. Most cabinet makers, for commercial use at least, use them to hang the wall units. Makes installation quick and easy. There is also a similar product used in retail stores, the cleats cover the display walls and many types of hangers are available to fit them. Kinda like peg board, many things fit peg board.
P
PapaBuilds
Nice, and love your garage set up 👌
P
PapaBuilds
A couple years ago I had get some space back to actually park a car, so the walls got filled up. Not shown are the summer chairs that would be hanging over other folding chairs. Now almost all the clutter is hanging on walls or shelves.
Very nice!
Codyboy
S.E. TEXAS
Not familiar at all really.
Just looking at the geometric shapes working together it seems it's all upside down.
If the angle were at the top it would eliminate the locking blocks. The weight would sit on the squared edge(bottom) and act as a kicker.
The angle on top would in no way be able to pop out until the wood broke.
However I can see with my idea if the fit was tight enough but with just a little slack , then they would have to slide in from the ends.
But if it is working for you good job! More ways to hang stuff is always good!
P
PapaBuilds
True, there's more than one way to skin a cat
firebirdparts
Kingsport, TN
Good idea. If somebody wanted to copy that, I think could be made more secure, but it would be a lot more work. Probably pretty strong as it is.
Upside down cleats is also a good idea here.
Smilodon
Titusville, FL
I'm for overkill as much as the next guy, but don't you think that lift for the bicycle is a bit much? :lol2:
mm08822
I would think a 45 on the underside of the upper cleats and matching angle on the bracket would be needed.
Then maybe a shim under the bracket on the lower cleat.
Beerhippie
Far NE Oregon
If the weather is about a hailstorm, then I justify it. Otherwise I park in the driveway, but not before I drive on the parkway.
There are still rigs on the roads hereabouts with scars from the Great Wallowa Hail Storm of... well, about ten years ago. Look like they've been thoroughly worked over with a ball-peen hammer. 1-2" hailstones and 100 mph winds. Megaburster event.
No one had time to move a rig into the garage.
