TS210 Over Ghostshield 8510
Pompey
Now that the warmer weather is here, I am intending to treat my 35 x 60 shop concrete floor with Ghostshield 4100 Intensifier and Ghostshield 8510.
In order to get a better oil resistant finish, can I then apply a coat of TS210 over the fully cured Ghostshield or is this not possible ?
Treeman
The guys at ConcreteSealersUSA will answer your question and they prefer to talk directly on the phone so that no questions go unanswered. They are top notch and sincere about not having any failures with their product.
Shea
California
Great idea, but no. ;) You will have effectively sealed the concrete with the GhostShield system. You would need to remove it via grinding to apply the TS210. You can apply a penetrating sealer or a topical sealer but not both.
P
Pompey
Thanks for all the advice. I will leave the 8510 uncovered and save myself some time and money.
I just ordered some spiked shoes so that I could walk on the 8510 and apply the second coat without leaving footprints
Garage Flooring
Grand Junction, CO
Its important to understand the process.
Lets say you have a large building and you are using a densifier followed by 8510. In this case we presume you are doing the two step method.
Densify. Make sure no mixture is left standing. Wait 7 days +
Now on the 8510 you spray 'a line' along the back wall. Wait for it to soak in. Spray it again. Repeat working your way out of the building. No need for shoes.
P
Pompey
Thank you for the information ..the building is 35 x 60 so yes I could spray down the long side , starting at the back
