Tube bender for smaller diameters
guy2600
Northeast
There are a lot of recommendations for tube benders for larger applications. For my uses, I'm bending 1/4" and 1/2" 16 gauge tubing in mild steel and aluminum. Also, I'm just starting out, so I know next to nothing about them. Any thoughts on these options? I'm seeing three different types:
This type which seems to be able to make a wide variety of bend radii but they seem to be geared towards larger diameters and can get pricey.
This type which seems to bend at a fixed radius for a given tube diameter. They also have reverse bend options (I still don't quite understand what this is).
This type which seems to be the most economical of them all. Not sure if this will bend what I need or what the limitations are vs the one above.
Ditchdigger
Eugene, Oregon
The first one you have pictured is a tubing roller. They will indeed to large radii but no sharp bends.
The third is what I believe you are looking for. They are used for hydraulic tubing, AC lines, Power steering lines, and brake and fuel lines in steel, stainless, copper and nicopp. Easy to use and powerful.
slowtwitch73
Hellgate
It's need specific.. what radius etc.
The Rigid 358 style geared benders work really well but only a few sizes are offered... spendy unless you can find used. I use mine on 4130.
Hossfeld, Diacro, etc etc.
jfleisher
Marysville, Ohio
Will any of these work?
LXCam
I have all three and I’d suggest #3 for what you want to do. I just used my imperial 1/4” tubing bender to form some hangers out of 1/4” pencil rod recently and worked great.
isb cornbinder
I have every size of RIDGID Lab tube bender. Picture 3 looks like an Imperial tube bender. I have the Imperial. I had my first Imperial break at the joint wile I was bending some 1/2" steel tube. Imperial replaced the damaged bender, no question.
isb cornbinder
TurnipTruck
Southcentral Alaska
These Swagelok tubing benders are the best I have ever used as a professional instrument tube installer, but they are several hundred bucks each new and are overkill for aluminum and steel. You will need a bender for each size tube.
The imperials are completely adequate for what you need.55628F66-12FF-4933-9762-D0BE6783CEBB.jpeg
rustyzman
Chicagoland
My personal choice is the Holesclaw geared bender. I believe Imperial took over making them new, now.
I have a couple sizes and it is what I use for copper and brass. I have not tried in steel or stainless, but I believe it could do it.
2oolhound
BC Canada
Not sure if you can still get the World Ware benders. Maybe used on ebay. I found this one for $20 or so.
joe_padavano
Northern VA
Imperial 364-series is by far the best. I use these exclusively for automotive tubing, often stainless. I got all of mine used at swap meets or ebay.
zmotorsports
Northern Utah
I have the Ridgid HD version which is very similar if not exactly like the Imperial and Swagelok branded small diameter benders.
I have the Ridgid's in sizes from 3/16" up to 1/2" and they have been nice quality tools. For anything larger I move to my JD2 tube bender.
I like the HD version of the Ridgids with the rollers and feel they don't mar the surface of the tubing as much as the stationary shoe style plus the handle rotates so you can bend to a tighter radius when needed.
