joshuaz223
had a job that required a lot of notches in tubing. i have wanted a better way than angle cutting and grinding so after a little research on various designs and a look at the scrap available this is what i came up with.
started off by cutting off a piece of 2" plate
remove metal till you have this
make some clamps
a support arm and bearing block.
pivot pin
drill shaft
the completed project
make some clamps
pivot pin
drill shaft
