Tube Roller Capabilities
BarnBuiltBeaters
What are the capabilities of a tube roller (specifically the Harbor Freight one)? I have a couple of pieces or 2" .120" wall steel tubing that I am looking to bend in the below shape. I need this to go around the 8" coil spring and am limited by space between the coil and the red bar (crossmember)
Would I be able to make the below part using a tube roller (9.5" centerline diameter)? I know a tube bender is the way to go but they also cost a fortune. I do need both bends, I just made a simple model to replicate my needs.
Thank you
speed bump
Butte Montana
If I remember right the minimum centerline radius is like 10 inches and in 2 inch .120 wall in not sure it will hit that especially before it wears you out. A roller is really for stuff that is a big gentle radius.
I would either ask your steel yard if they do bending or get ahold of someone like cornfield customs to bend it if you don't want to invest th $1000 in your own bender. Or there is always pie cuts and welding them together.
Firstram
You could do that with the HF roller but, you would have to do it in 3 parts. Rolling 2”x.120 tubing would kick your *** and the bends would be flattened and or helical. The Swag roller and dies are so much more accurate they would make excellent parts but, that’s $1200, 3 pieces and it would still kick your ***!
Outsource the parts!
