Tube Steel Load Capacity
ztrabun
I am looking to build a large barrel rack. The rack will be 12ft tall, 3ft deep, and 17ft wide. Each barrel is 40" wide and when full will weigh approximately 1500 lbs. I was thinking of using 3x3x.25" tube steel as the frame. Can someone tell me if the longitudinal length (17ft) will be strong enough to hold approximately 6000lbs of weight distributed evenly over the length of the rack. Crude picture attached
matt_i
I would think something like a S6 x 12.5 I-beam (or better) used in triplicate is better. The 3x6 box tube with 6" dimension vertical is a close second, also used in triplicate.
Stick weld every joint, E7018 is my recommendation.
Across the 17' I would X-brace the beams in the plane of the top surface, or plate with steel (to be included in the weight). I would angle-brace (gusset-brace) the connections to the posts. Epoxy anchor to a concrete floor on foot-plates.
Seems like a simple structure but a lot of risk here.....
bon3s
Uniontown, OH
We build things like this at work all the time, Id stay away from anything square and as the above have said go with I or H beam or with a rectangular tube as they are more rigid, additionally cross braces, gussets and the third rail should all be done no matter what u decide for materials.
Depending on your welding skills as well as what welder you have access to, this can very easily done with mig as well as stick.
davewo
USA
Go to Home Depot and observe the pallet racks they use to hold tons of concrete.
red92s
Pallet racks don't span nearly 17' (probably more like 10'). It's the really wide span without a support that's killing him, not the heavy load.
bigguns69
Iowa
You can see my calculations and the beam table from machinery handbook. The 3x3x1/4 wall tube calculates right out to the yield strength of general structural steel, A36, 36,000 psi. Need to shorten the unsupported length and or add more beams if you want to use this material. You could use: 4x4x.25" wall would give you a Safety Factor of 2, 3x6x.25" gets you a SF of 1.85, 6x8.2lb. channel will get above SF of 2. You want a section modulus, Z in the x direction of 4.2 in^3 to get a SF of 2. Then you are good. I would gusset the beam, more for the legs, given the height.
jimgood
Marshall, VA
Hmm...now I'm suspicious. First time poster. 1 post. No response after all this advice? Either a troll or seriously rude.
tapered-pin
Alpharetta, GA
lol, you won't have to worry about that from me..
(hi, y'all)
I've found that most people just want you to tell them their plan will work, regardless of how insanely under-engineered it is..
