Tubing bender, dies, etc
rattle_snake
Chandler, AZ
Looking at getting a bender setup, like a JD2, Pro-tools or similar. Use is mainly automotive; chassis, cross-members, etc.
Don't have room for a dedicated stand so want to convert to HF air/hydraulic. Looked at many options for ram mounts including the swag unit. Probably make my own because I'm cheap. Is a return spring a must have?
Pondered going vertical or horizontal, or even perhaps configurable to do both. How solid does a cart/stand need to be to bend accurately? Can a engine stand be used? It already has provisions to rotate. I'll be fabricating whatever is needed.
:headscrat
Dies. Should I get all 180* dies? Since they are around $300 each, I want to start with a pair and buy as needed later. Thinking 1" and 1.5. I know roll cages are typically 1.75. So maybe 1.75 and 1.25....
:confused:
Does the degree wheel work well enough? Angle finder better (only vertical)?
Any particular good bender software?
Any input appreciated, thanks.
silverj53
tx
:headscrat
:confused:
Bend-Tech Pro is a great program, fairly easy to use but pricey.
silverj53
tx
Also i use a vertical homeade bender with an air over hydraulic cylinder from harbor freight, and a magnetic digital angle gauge. I have good success with the setup.
dr_clyde
Holland, MI
I use a JD² model 3.
It is a very good bender for the money.
Buy 180° dies, there will be times you want more than a 90° bend.
I have never used the hydraulic on a JD², we always just anchored the bender to a heavy bench. You have more fine control with a manual, its harder to sneak up on a bend with the hydro. Sometimes you just need to bump a degree or two.
The degree protractor is accurate enough for custom work, I wouldn't want to use it for production bending. It is fairly simple, just a piece of welding wire held over a protractor head. You set zero before bending and stop when the wire is over your desired degree.
Bretny
Dutchess county NY
I built benders that took jd2 dies but is thicker metal snd wider plates. I still have 2 that i can sell. They come with the HF long ram adapter. Pm me if interested.
Mine is setup on a moveable stand with a pivot. It takes up very little room and folds up verticaly. Its basicly a pipe with 4 legs that have screws for fine tuneing level with a pivot at the top. It uses a 3/4in bolt for the pivot.
I use a engine degree wheel for the degree wheel. Also you do need a return spring. This is a garage door spring with a paracord safety.
Craftfab
Garage
I use a JD2 Model 32 electric/hydraulic. Just got it a few months ago and very please so far. I need everything to be on wheels so I went with hydraulic vs manual. 180 degree dies because they are not much more than 90 degree and I felt worth the investment. Most stands are very similar to an engine stand with a thick flat plate on top to mount. JD2 has a PDF they will send customers wanting to build a stand for their benders. I started with 1" and 1.5" dies for a mix of furniture and automotive projects (I'm just a hobbyist). My next die will be 1.75".
jdewitt
Here!
No real experience to speak of, but I really like the design of the Hossfeld #2 bender. Looks quite versatile.
This old Tony video:
Ign
Butte Peak ND
Yes get all 180 dies.
I think the degree wheel *****, never had any luck or repeatability with it. A scale to measure actual travel works far better and I do use this for production.
Wanna Ride
Looking to buy a bender in the next few days and want to ask some questions: I'm only using it for personal projects and maybe a few paid jobs here and there. I won't be using it daily, but I also want it to be reliable for when I do use it. Not opposed to using it manually, but I'm open to upgrading to hydraulic it later. Maybe right out of the gate, it just depends, I suppose. Anyone have and regularly use a Woodward Fab bender? How about the SWAG stuff? I've got a few other SWAG items (the portaband saw table), and that stuff seems to be ok. What about some other less-expensive brands, or should I just go ahead and get a something else? I'm ok with spending a little more if necessary, but not just because.
Post up some pics of yours and the stands, etc for ideas.
