tungsten grinder for Dremel
astroracer
Mid_Michigan
I've looked at them but never pulled the trigger. I use an electric drill to spin the tungstens against my block grinder. Literally takes less then a minute to sharpen on up.
Mark
T
that-guy
NoVA
Mark
i do the same thing, but not always with a drill, however i am looking for a more consistent grind, which is why i am looking into this...mine tend to vary in degree of the grind and i'm trying to prevent that
kabinenroller
S.E. Wisconsin USA
Interesting. I have beeen thinking about purchasing something like this. I also use my block grinder for sharpening my tungsten but I am sure a dedicated stone and a precise guide for the angle would help my welding.
$40 including shipping is not that big of a gamble so I may try it. The eBay auction is directly from the manufacturer and they are located in the Midwest instead of some China junk which is a bonus.
T
that-guy
NoVA
my point exactly...i may pull the trigger and write a review...the diamond wheel even looks like the same that you can buy from any hardware store for the rotary tools, so at least it won't be hard to get replacements
screw it, just ordered. will write a review and post a video when it arrives :pimpflash
Bigblue&Goldie
I'm curious how it mounts to the rotary tool. Universal fit usually means universally poorly fits.
kkroger
I have a Sharpie brand tungsten grinder that I took off the corded Black and Decker motor and put it on a cordless M12 Milwaukee Rotary Tool... I like it a lot, you can get them off E-Bay pretty cheap if they are non working I don't think I would want one on a Dremel.. it is a lot lighter and more compact than dragging a Bench Grinder and a Drill around with me... in the shop I use the disk sander...
T
that-guy
NoVA
I just picked up one of the Eastwood tungsten grinders. Works great, not huge money and no need to change tooling back and forth on another tool. I got mine for $80 when it first came out which worked out to a little over $100 for me due to the exchange rate. Worth the money IMO.
https://www.eastwood.com/eastwood-tungsten-grinder-57555.html
was looking into this as well since i use an Eastwood TIG200, however i still didn't want to pay $100 since this isn't my profession, so i'll opt for this cheaper option...still waiting for it to arrive, then the testing will begin
pgk
St. Johns MI.
I found a wet grinder years ago for a pretty good price similar to this one, it needed a new diamond wheel and a few other parts. Works good and gives very consistent grinds. If I had do to to it over again just chuck your tungsten up in a drill and use a belt sander or grinder while very slowly turning the tungsten, after awhile you get pretty darned good results. I couldn't believe how much these type of grinders go for brand new, crazy.. https://www.arc-zone.com/tungsten-e...cision-liquid-tungsten-grinder?cPath=15_2423& Everyone always says to use a dedicated wheel to grind which is probably a good idea, although I know a few welders that Tig all day and some of them use what ever is the closest to them, and their tigs welds are amazing. I guess if you were doing critical type welding it would be worth following proper sharpening guide lines. I'm just a weekend warrior out in my garage, any critical welding I leave to the pros.
Pete
T
that-guy
NoVA
well, the seller finally shipped it yesterday. not sure what took so long, but oh well. atleast it is finally on the way and i can use it whenever it gets here
goat1252002
I have one of the older Scottsman tungsten grinder on Milwaukee rotary tool. It works I just don’t like that it has a one-size-fits-all tungsten hole. the new model looks like it would work better with sized collets. I’ll probably get a Sharpie DX grinder tho
T
that-guy
NoVA
that was one of the main selling points of this one for me, as with the Scottsman, you'd have to buy the other collet sizes separately, and have to switch them out as you need to
shipping information finally updated and should be here Tuesday (stupid Memorial Day holding up shipping) so stay tuned for a review next week
BWS
Mnts of Va
Scott Murray expanding drum sander head.The "belts" pop right off when switched off.Keep a dedicated belt for tungsten on it 90% of the time. Occasionally a job comes along we need it to grind something else,pop another belt on?
Drill motor to turn tungsten.
Slackerzinc
Edit: version I got was 100% plastic.
When you sharpen a tungsten it heats up and the plastic melts. I am going to drop it off at my buddies shop and see if he can make me one out of aluminum.
T
that-guy
NoVA
as said above, it is made out plastic. it attaches easily to the rotary, however you have to remove the blade to remove the plastic housing to then adjust the height of the blade, so adjustments are time consuming.
unlike the above user, i have not had any issues with the tungsten getting so hot that it melts the plastic, however i can very easily see how that can happen. if it were aluminum, it would be a far better product, but i am otherwise happy with its results
racingtadpole
The far side of crazy.. but sometimes Australia
So I bought one of these a little while back and have been using it for a few weeks, so here’s my thoughts for what they are worth...
It’s a solidly made product, finish is good and it fits on the Dremel smoothly. Alignment of the disc relative to the guide, whilst looking a bit cumbersome isn’t. I had mine sorted in under two minutes and I imagine most of you looking at one have sufficient aptitude to do likewise. The guides are pretty simply made and thread easily into the plastic housing once you get them started. I say that because twice now I have attempted to cross thread mine because I’ve not been paying attention to angles (best you don’t use power tools whilst drinking anyway :lol:). My only real complaint, and again this is my doing, is that I didn’t swap out the 1/8” guide for the .040” guide when I ordered it.
I decided to put it on a new 2 speed Dremel so I had a dedicated grinder, my advice here is put it on a variable speed Dremel because the slowest speed on the two speed unit is a tad too slow and the fastest is too high by an order of magnitude. I’m guessing the sweet spot is somewhere in between and requires the purchase of the more expensive variable speed unit to find.
Putting it to use the grinds are consistent regardless of size guide and in this case the speed of rotation selected (although in high speed you need to keep it moving or you will flat spot it quite easily).
If you ball a tungsten beyond the tolerance of the guide you will either need to break it off or grind it on something else to knock the ball off first. I generally just break the contamination off but if you are just starting out that could get expensive.
I’ve not had any of the heat related issues noted above, and didn’t have any real hassle setting the cutting disc relative to the guide entry.
An unexpected benefit seems to be the 20degree taper I decided on balls off quite minimally and uniform on AC (I have an inverter) and is useful for thin material.
Pretty solid tool for the money in my opinion, and certainly quite a bit cheaper than any of the other similar styles of dedicated grinder I’ve looked at. Having said that I have no affiliation in any way with the manufacturer, my choice to purchase one was based on nothing more than seeing this thread (yet another tool I didn’t know I needed until GJ).
BD1
north side
VR6ix
Onterrible, Canuckistan
When I finally got a small TIG the next thing I did was scan the local classifieds for a bench grinder. Kept the fine-grit stone on one end and promptly hit Amazon in search of diamond disc wheels that fit the spindle.
Roughly $20 later I had both a 240 grit and 500 grit uxcell disc in the mail on the next boat from China. It all works great, using the stone for cleaning and the dual diamond discs to smooth things out. If I did it again I would get a better grinder and go one step higher grit on both discs. I don't weld a lot but they are holding-up nicely and have plenty of bite into tungsten.
ericlar80
California
I use the same Harbor Freight diamond disc that BD1 linked. I ended up just mounting it to the outside of one grinding wheel on my block grinder. The arbor on the block is 5/8, but the hole is 18mm on the disc, I think, so a it's a little big. Some people make an adapter, but I just got it a little snug, bumped it around until it was centered, then tightened the arbor nut up to completion and it's not going anywhere now.
The HF disc is awesome. Couldn't be happier with the purchase. It really sharpens the tungsten up quick and makes a really nice point. Without any dust!
jeepinerdeep
South Central PA
I bought the TungstenMate, Delrin version. I think its great. I am a casual user, and not running production. I split the difference and ordered the 15 degree. It's mounted to an M12. It seems to be the best value for me by far.
It's 9/28/18, I understand that TungstenMate added the steel bushings this summer and also added the alloy option around the same time. In order for them to get a fair shake, I think the guys that said it's melty junk should clarify whether they used the version with bushings or not. I'm guessing not.
briantang
Madrid
Hey guys, I've been using electrode sharpeners but haven't had good results. I have been searching the internet for new tungsten electrode grinding machines and I have found this tungstengrinder.net website. Does anyone have experience with it? Has anyone bought here? Any recommendation or help will be very useful to me. I want to improve my workshop to offer quality and guarantee to my clients.
bdbecker
Iowa
Welcome to the forum!
It looks like that website isn't actually selling anything, they are just redirecting to Amazon using affiliate links to make money. Amazon doesn't always have the best pricing on welding items, so it is worth looking around a little.
https://tungstengrinder.net/affiliates/
briantang
Madrid
You're right friend, thanks for your opinion. I really had that option to buy my tungsten electrode grinders. However, as they are amazon affiliates, amazon prices are maintained. In addition, I have been evaluating prices in other suppliers and at amazon I have obtained the best prices.
Have a nice day!:thumbup:
