Ihateclevernames
Gents, looking over the air compressor I felt that it was about time to do a little cleaning on it and give it a good once over.
Drained all of the air out at the top and then opened the drain **** on the bottom and found a lot more moisture than I was comfortable with. Some looked rust colored, but didn't notice any metal in the small puddle of water.
The drain **** was also somewhat damaged upon removal, so i figured now was the time that I need to do some upgrades for managing the water, like some sort of catch on the bottom of the compressor or at least making it easier to drain with a ball drain valve so I can drain it partially and remove moisture that has settled.
Not to mention, preventing any further damage to the tank. Is there anything that i should put in the tank that will help sop the spread of rust? Or am I just going to have to keep an eye on it?
The compressor itself is only about 6 years old and it wasn't drained all that much. However I did drain it several times a year whenever leaving town.
Since the drain screw on the bottom appears to be damaged, are replacements pretty much universal for compressors? I have no idea where the piece is as my shop is still under construction.
Thanks in advance!
Thanks in advance!
