Turpentine - How do you discard it?
Cypress
Colorado
I’ve been doing some painting / staining projects around the house and have been using turpentine to clean poly off of my brushes. What do you guys do with that stuff after you soak your brushes?
Maybe I’m just dumb and there is a better solution to cleaning brushes...
Thoughts?
cowboy73
southern Indiana
Do you have a fire pit? If so, just pour it on the wood and have a fire. I wouldn't roast hot dogs over it but it will burn up with the wood. If you can't burn it, you could set it in an out of the way place outdoors when nobody will get into it and let it evaporate. It won't take long.
wolfhawk73
Eastern North Carolina
I use paint thinner instead of turpentine, but maybe this'll work for you. Do solids settle in the old turpentine? If so, continue to use the old turpentine until it's not effective.
I have an old gallon can of paint thinner that I constantly reuse. It's almost half full of solids from settling. I just pour a little off the top into a quart bucket for the first brush rinse. A final rinse with a couple of ounces of fresh thinner gets it nice and clean. All used thinner goes in the old, used can.
I've only bought two gallons of thinner in the past 7 years or so, and I haven't had to dump any yet even considering all my little projects. I currently have about half a gallon of clean thinner and half a gallon of used. The other gallon is gone from drying the brush and allowing the thinner to evaporate.
When you finally have to dump the used can, most local municipalities will take it for disposal or recycling.
LeonardY
Southern California
I have switched to water based finishes so brush clean up is easy.
To answer your question. I dispose of chemical waster at community hazardous round ups. Or I take it directly to permanent collection locations. You can call your local waste company and get that information for your area.
I went through my dad's garage a few years back and found all kinds of chemicals dating back to the 60's. Some of the bags were labeled DDT. He said to me, "You know, you can't get that stuff anymore." I said, "Yup, that's why I'm taking it."
I collected it all up and disposed at a hazardous drop off location.
Shiftless
East Bay SFO
That’s the best.
Most of us “of a certain age” have stories just like that where we went into the storage areas of our dads and FIL’s and found lots of dangerous stuff.
My FIL used trichloroethane in his little shop. It’s a fantastic solvent and degreaser but it attacks nerves, blood, AND your liver. :(
He also had plenty of DDT and chlordane insect killer. That stuff was widely used to kill termites until it was banned in 1988.
yeldogt
I reuse both Turp and mineral. Have some big glass pickle jars and I let it settle ... when cleaning I dump the settled product into an old coffee can and clean the brushes .. dump it into another jar ..may do this four times ....how much I use does not matter. The last is a small wash with new .... it all goes back in the main jar to use again.
Turp is the best last wash for a brush.
C
Cypress
Colorado
Ok, so it sounds like I should just be re-using this stuff after the solids settle. Makes sense and no dumping required. I like that!
Old Man Roger
Palm Coast Florida
That’s the best.
I was a pinsetter mechanic in my youth. We would put Trichloroethane in a bucket and just dip a rag in it to clean the pinsetters and the ball lift belts.:shocking: I've inhaled and bathed in that stuff.:wtf:
wssix99
Chicago, IL
Yes. Keep an old can for the used stuff separate from the new and if you want to dispose of it, your local municipality will have a special hazardous materials disposal place/procedure for your area.
toolin' around
Los Angeles, CA
I always used turpentine with linseed oil or tung oil for a natural wood finish... and denatured alcohol (called methylated spirit in Australia) with shellac for fine furniture finish... wanted to finish some doors recently, and discovered that both are now not available for sale in California!!! Seriously!!!
Mineral spirit is an ok substitute for turpentine, but there’s just no substitute for denatured alcohol.
Fortunately, I had to go to Vegas recently, so I stocked up on both. (Felt a bit like a bootlegger driving back into California!)
Skiff Builder
Southern NJ Coast
Your half way to "Boat Soup"
Turp
Oil- BLO/Tung/Walnut/ etc
Pine Tar- (Stockholm tar is best)
Japan Drier
Been used for a long time on the water. Tar is the preservative- the others get it in the wood. It breathes and will let wood dry after being wet.
Old Man Roger
Palm Coast Florida
Ahhh.... The good old days, huh?
Ya, and most of the houses I grew up in had asbestos exterior shingles, floor tiles, and pipe insulation. More than a few had dirt floors in the basements that were probably 50% asbestos dust.:scared: Don't get me started on the tons of brake dust I've inhaled over the years, probably done a million brake jobs..lol
nadogail
Coronado, CA
Back on my first enlistment we used Tri-Chlor for everything; we even cleaned coffee cups with it.
Miss the Pontiacs
Saskatchewan Canada
When I was at work The Telephone Pioneer organization used to do a one day paint recycle at a number of cities in the province. My job was to make sure we had the volunteers and have them scheduled over the weekend. Also to make sure they were feed and watered.:beer:
We would decide if the paint was reusable or scrapped. If scrapped we would dump the into a sealable barrel. Didn’t matter if it was latex or oil, turpentine, mineral spirits or or some type of thinner. As long as it was a paint item and not some type of chemical.
We had industrial can openers, aerosol recovery equipment and even had a paint can crusher made with a series of large spaced rollers and moving down to a pancake size opening. That was pretty cool piece of equipment.
I made many wood scrappers from chunks of scrap wood approx 4”x12” probably old fence board. If you cut it properly you got 2 equal scrappers per piece. The scrap of the first cut should be roughly the inverse of the other, so 2 scrappers per piece of scrap. Then just put a 45 degree cut on the blade portion for scrapping.
The barrelled material was sent to a plant where they added it to the fuel for some type of burner that used it create heat for their manufacturing process.
It was surprising how many cans even 5 gallon cans that were brand new and never even opened. I’m still kicking my self for not scoring 4 gallon containers of Texaco green in cans actually marked for and labelled Texaco that were pristine.
Boatman62
Cleaning brushes>>> How about Brush Cleaner! Been in the antique boat business for 30+ years and brushed on 1000's of gallons of varnish and paints. Brush Cleaner is the best I have used. Clean the brushes in a 5 gallon bucket and the solids settle out. Then a quick rinse with fresh cleaner that gets dumped in the bucket. Every couple years I dump the liquid in a new bucket and take the solids to our recycling center.
c39er
Seattle, Washington
It shows!
You have not aged well judging by your picture😄
santagary
Pagosa Springs, Colorado
I use a couple of teaspoons of old used turpentine to sweeten the smell of my weekly trash load of household trash including kitty litter. Keeps the flies away and the trash guys are grateful. Keeps the bears away from the dumpster also.
Old Man Roger
Palm Coast Florida
It shows!
No that's human Popeye in my avatar, this is me.
CJDave
Fairfield, Ohio
So your avatar is not actually a recent picture of yourself. Good to know. CJDave.
frank001
Southern California
I do the same thing when I go to Vegas or Laughlin. :beer:
