TV Wall Mount on Square Tubing
crooney1189
Hernando, FL
How is everyone mounting their TV wall mounts when the mount is landing directly on a column? The mount will be a vertical 3-hole style centered on the middle column on the enclosed gable. Tubing is 14 ga 2-1/2" square. Self-tappers don't seem like they're going to cut it here... Is there enough meat on the tubing for lag bolts?
Codyboy
S.E. TEXAS
I would through bolt it.
Use rubber washers or sealant on the metal siding outside.
Drill where the flats are in the siding and not on the ribs.
Codyboy
S.E. TEXAS
This doesn't pertain to your OP , but are there gutters on the roof between the two buildings?
Looks like you'll be dealing with a lot of runoff and splash if not.
C
crooney1189
Hernando, FL
Yes there are. The first picture was older but it showed the enclosed gable end. This pic shows the gutters
claymont
CLAYMONT, DE
Rivnuts will do the job.
Knurled Round Body Rivet Nut Thin or Near-Flush Head
PoorUB
Fargo, ND
Hose clamps?
A couple of them wrapped around the tube and the base of the wall mount would probably do it. This way you will not be drilling into the column and possibly weakening it.
Skooterj
Indiana
Would you even need a rivnut? Just drill and tap the post? Thru bolt would be my first thought though.
aka Larry
Eastern, NC
IMO, you are overthinking it.
My shop is constructed the exact same as yours and almost the entire structure is held together with self-tapping screws. I have quite a few items mounted to my columns in just that manner.
How heavy is the TV? Less that 50#? I'd use (4) self-tappers and never give it another thought.
Stuart in MN
Minneapolis
A couple of hefty U-bolts fastened around the tubing? Most are made for round tubing (like muffler clamps) but there must be some designed for square tubing.
KwikFab
Central Valley, CA
Agree.
Super simple.
I'd even donate the backplate if one is needed as that's the route I'd go.
Dig Doug
Through bolt a piece of angle side to side, then through bolt the TV mount to the angle
you probably only need some 1/4 or 5/16 bolts
@crooney1189
liliysdad
On that?
I’d do a plate with u-bolts around the square tube. Mount the TV mount to the plate, no holes in the tube.
no704
Some ate x screws will be fine. TVs are not as heavy as they used to be.
dcg9381
Austin, TX
Agree. Self tappers. As long as you don't have an 80" TV on a 3' arm that swings, you'll be fine.
aka Larry
Eastern, NC
I live on the edge. I have a pair of 80# kayaks supported with brackets that are held in place with (4) 3/16" steel-shank pop-rivets to the bottom side of my roof trusses. I ran out of self tappers...LOL.
CraigStu
Blacksburg, Va
I'd use at least one through bolt at the top. But probably, once I had that figured out, I'd just use 2 more vs self tappers.
dante2
Central OK
A plate inside the rib with bolts thru the mount would work for a TV. My camera monitor is mounted with 1 bolt facing out and the other in. My door hangers ended up the way. Square U bolts in your tube size work great on hanging anything from the ceiling.
C
crooney1189
Hernando, FL
Appreciate all the responses! Following up with the end result for anyone else looking to do the same. Ended up going with big square u-bolts and a large self-tapper for good measure. Had to notch the TV mount for the u-bolts to pass on either side of it as well. This avoids adding additional penetrations in the tube (other than the screw) and metal skin on the outside.
Should hold more TV than I can afford to put on that wall... Probably overkill but I was trying to be mindful of wind in an outdoor scenario as well, especially being in FL. I'll take the TV down before hurricanes, but even the afternoon thunderstorms that creep up during summer can pack a punch on occasion.
