geartow
This is the Blue Point I am using https://store.snapon.com/Disc-Brake-Tools-Press-Brake-Piston-P643045.aspx
2ndGear, your obvious lack of knowledge is a bit disturbing for doing "thousands of brake jobs". Old brake fluid contains sediment and contaminates especially as the fluid ages. All that gunk sinks to the lowest points, the calipers. When you don't bleed them you're pushing that garbage back up the line. Unless you have no other choice you're just being lazy by doing that.
Brake systems are not perfectly sealed from the atmosphere or oxygen free. They keep air transfer to a minimum with diaphragms but none the less every time you step on the peddle the system vents otherwise the master would implode.
Oxygen free environment? Not a chance. *yawn*.
Good luck selling a brake flush to every brake job customer.
I thought everyone on GJ agrees brake flushes are pointless?
Depends where you work and what you're working on. Unless you wallet flush a pressure bleed takes about 5 minutes. Longer if you want to go through the trouble of cycling the ABS modulator but that's not necessary. Brake fluid is cheap and should be largely replaced every 4-5 years at minimum.
In the mean time thousands of brake jobs are done each day by pushing the piston(s) back into the caliper..
It's also another $100 on top of a $300+ brake job.
