Twisted off a bolt on a trailer axle.
Bubbles
Bought a new to me trailer, a nice double axle one.
started taking the wheels off for new tires.
No one ever told me one side was reverse thread. I twisted one off flush. :mad:
Honestly I would of probably twisted them all off if I didn't hit forward on the impact gun to try to loosen them.
Think it would start to turn if i drilled it? Would rather not try and get fancy and weld a nut on it.
Thanks
APEowner
Sunny, New Mexico
Thanks
There's a good chance that it'll walk right out if you hit it with a drill. Generally when a bolt is snapped off from being over tightened they turn pretty freely.
Bubbles
I'm gonna try.
next question. are these bolts easy to buy ? should i be able to get them at a hardware store or online?
joe_padavano
Northern VA
I'm gonna try.
Left hand thread wheel bolts with tapered lug seats. Oh yeah, the hardware store is gonna have those... :eyecrazy:
Seriously, either go to a trailer supply house or just order on line.
Here's another tip. Next time, look for the "L" stamped on the head of the bolt before going crazing with the impact wrench.
pepi
Woodstock, GA
Thanks
New one for me, never heard that before RH & LH lugs, yes back in the day I think Chrysler was know for that. Are you sure it is threaded, my guess it's a press fit stud. Might be $$ ahead and replace the hubs on both axles on that side...
Did a quick search for ya, found there are both, threaded and press fit studs ... new problem for you to solve.
http://www.ptrailerusa.com/wheel-studs-lug-nuts/
Bubbles
Thanks, I found a few spots too.
It use to be a camper trailer, someone took the top off and saved the Chassie.
lesson learned i guess.
stage20
pcola FL
If it's pressed in you can knock it right out with a punch. May be easier to replace hub if it's a booger
APEowner
Sunny, New Mexico
I revise my original answer. I was thinking that it was a lug bolt that the OP broke off. If it's a stud then it's probably pressed in and it'll knock right out.
Marctrees
TX/LA border - Toledo Bend
AHH, yes, maybe thats why he was talking about welding on a nut come to think of it.
Well then, back to the drill, easyout thinking then. Marc
pepi
Woodstock, GA
On the backside of the hub, do you see what look like mushrooms? If so they are pressed in, now that you have a hole drilled. You have relieved some of the force of the stud too the hub, you can knock it out, try to use a punch just shy of the size of the stud.
csp
Franktown, CO
A picture of this trailer hub would clear up a lot of the questions and suggestions on how to remedy it.
metaleltr
Western Ohio
Being that this trailer had a former life as a camper and is obviously fairly old I believe the op is dealing with a threaded wheel bolt not unlike that used on vw and bmw, however these are probobally a 1/2 fine thread. So these metric European wheel bolts are of no help to the op hopefully this will help the brain trust see the problem through the op's eyes.
MJD1
Check with farm implement places. The tapered head lug bolts where real common years ago. 1/2" fine and 9/16" fine where very common. Otherwise pull the hub, drill out the holes and use pressed in wheel studs.
