The Wizard
- Joined
- Apr 9, 2010
- Messages
- 88
Guys, as the title states, I have two 120V outlets in my garage which are no longer getting power. They are both the outlets located on the ceiling for the garage door openers to plug in to (one outlet for the two door garage, and the other for the single garage). I have tried the obvious: Checking the circuit breakers on the side of the house - all good. And cruising around the house making sure no GFI outlets were tripped - all good. Tried replacing the outlets - no luck.
Any advice you guys can give me on how to troubleshoot or fix my problem?
Background, if needed: The first outlet lost power about 2 years ago. I was dumb and I sawed through an extension chord plugged into one of the outlets. The second outlet failed just a few weeks ago when I apparently overloaded it with a blow dryer and a heat gun at the same time.
Thanks in advance for any help etc, I really appreciate it.
